1 - 2 of 2 Posts
Will this work ? Because im trying to do my mpfi swap on my d15b2.
So far i have the following parts:
OBD1 ECU
OBD1 injector clips
Boomslang dpfi to mpfi obd0 to obd1 conversion harness
D16a6 Complete intake manifold(throttle body, fuel rail, injectors)
Resistor Box
A6 ECU
Should i sell all the a6 parts and just get a complete Z6 head? I can get a z6 head cheap from one of my friends for like 50-60 would just need diizy and complete im.
If you're just trying to do the DPFI to MPFI swap, you don't need to go OBD1. You pretty much have everything you need already: PM6 ecu, A6 IM w/ all sensors, and you might wanna get an Si harness to snag the dizzy plug and injector harness for a cleaner install. Just do a search for DPFI to MPFI swap and you'll need to run 4 wires into the cabin to the ECU, repin a couple of pins, and you're done. If you're truly set on going to OBD1, first do the DPFI to MPFI OBD0 swap, THEN convert to OBD1. You'll save yourself a TON of headaches and will become more familiar with your car at the same time (ALWAYS comes in handy later....TRUST ME on this one).
1 - 2 of 2 Posts
