1 - 7 of 7 Posts
K
i know this topic has been argued many times but the master of dmotors himselft clearly stated that the a6/b7 heads flow the best out the dseries heads.
my ? is does the a6 head stock actually flow better than a z6 head stock. i cant afford to get a head worked on right now and i have both heads available to me so i want to know the best bang for buck option i have.
i know one advantage to the a6 heads is you can run a pretty nice camshaft due to the fact there is no vtec.
what is VTEC????
just a cam change right, make the motor a little soft to be more streetable.
More wasted motion also, which robs HP.
Race motor = non VTEC.
K
transzex said:
what is VTEC????
if i was doing a straight race motor i would go d16a6 no doubt. but my ? is for a street/strip car with cam and ihe and some good tuning which car would benifit more.
for example on my p29 motor i was running a z6 head. if i had an a6 head would i have noticed a difference off the bat or do both heads need to be worked to notice the differecne in power.
i guess the only way to find out is to dyno the two motors. maybe another future dyno day.
A6 the best flowing head??? Umm this is a new one to me. I was always under the impression that the Z6 and Y8 were up for that award.
Are the A6 valves not smaller as well???
K
well i was told this by the master of dmotors bizi him self. i met both him a wil from exospeed at idrc races in phnx az this past yr.
although we were refering to worked heads. my ? is for realatively stock heads with a cam and ihe
05 Wrx
Smaller valves have higher intake velocity and lower engine speeds, so at lower rpms a smaller valve will flow better. So it is more of a question of intake velocity of the flow bench. But I do believe the A6 has the better flow characteristics.
1 - 7 of 7 Posts
