D-series Janitor
Front Engine Dragste
Already bought an a6 cam, just wanted to know if I could get away with using the b2 cam gear or not.
Also, saw a thread on the MPFI conversion with an automatic. I pulled my intake/throttle body off a civic EX. Am I good to go as far as the trans cable?
thanks
D-Series Destruction Master
As for the auto tranny, you need the pulley for the t-body off of a 90/91 AUTOMATIC EX sedan...I have one somewhere, but it'll be a bitch to find.
You can use the cam gear, its the same as the SI, but lining it up right is gonna be a BITCH.
Just use a Y7/Y8 cam gear and be done. IF you decide to use the stock cam, run it at the 1/2 tooth adavnced setting with the slushbox.
But don't expect any power above 6000 rpm.......
D-series Janitor
It is a daily driven auto car. So with the shift points and normal driving, anything above 6000 is worthless to me anyways.
Where is the best place to get a y7/y8 gear?
Also, how do I dial in my cam without taking off the head and not using a degree wheel?
D-series Janitor
Educated guess?!?
Right now I guess I will go for rotor pointing at cylinder #1 and hope the valves are closed.
The best Y7 gear in my opinion is an AEM. I had one on my civic it it worked great. I've heard good things about the ones form Rage too, but I am not sure if they make one for the Y7 or not.
y7/y8 = same gear
