I've yet to find anyone who has tried this mini me build.
Car: 95 civic EX with D16Z6, totally stock.
Engine: A6 block with Y8 head.
Usually people are taking cars that come with these non-vtec blocks and making them vtec but I'm making a vtec into a different vtec
Another issue: I'm going from an OBD0 block with an OBD2 head in an OBD1 car.
IMO this is a total Frankenstein. I have questuons: has anyone done this before?
Will the Z6 harness work with the Y8 vtec solenoid? Do I use the y8 dizzy? I'll be using the y8 timing belt.
I plan on using the Vitara pistons and rods in the block, then slapping the y8 head on it (fully rebuild with titanium parts) and trying to make the sucker boost with a turbo. My goal is less than 350hp ever. I'm good with anything under that.
Any advice helps, I'm a little lost on this one and I couldn't find anything close enough in the forums to what i need to do. Thanks in advance!
B7 Dizzy
Had the A6/Y8 combo in my CRX, had an A6 dizzy.
Discussion Starter · #5 ·
Thank you slo_eg8, for the links! My main thing is that the A6 block isnt stock in my 95, so the wiring is made for the d16z6 (including vtec wiring) and I really wasnt sure if the connectors would be the same shape. I really appreciate the links, thank you!!
