1 - 18 of 18 Posts
E
Hi
I was wonder if d16a1 rods would fit in a d15b6 or would i be better off using vx rods. thanks
"WHAT IF" he was using a D15B crank though?????
I found the cure last night while drunk, yep D15B crank, VX rods, PM7's......offset grind/destroke the crank to 82mm, pistons will be flush :)
Now to find a cheap (FREE!) D15B crank :)
The H Badge is it!
91 crx
ryan89crx said:
a1 rods will NOT work. the crank end is too big. vx rods will bolt nto the crank right, but they will most likely push your pistons up too high
didnt know this :)
my b.....
nice thinkin' transzex
E
If I used the PM7 piston in my b6 with the stock head how big of an issue will the 2 valve reliefs be and running a a6 cam with the extra lobes hanging out.
E
Is there any other rods that I can use with a pm7?
E
Bone, if I used crank from a a6 instead of the d15b is there a alternative in rods. I ask cause I can get one free and I still wanted to use the pm7. thanks
Lifetime Awesome Member
'89 CRX HF
a6 crank in a 1.5 block? the main journals are too small on the block and the crank will not fit
E
Or would I be better off just buying a d15b crank and mod it.
1 - 18 of 18 Posts
