1261 - 1280 of 1292 Posts
Discussion Starter · #1,261 · (Edited)
Got the B series crank main and rod journals measured, and also installed the main bearings and torqued the caps down to measure bearing inside diameter with a bore gauge for oil clearance measurements.
Handwriting Font Office equipment Gas Event
The clearances will be in spec, although a few measured to be at service limit, but I believe this to be differences in bearing washcoat thickness. Next time I do bearings in this engine, I'm going to have a stack of 3-4 sets to pick and choose equal to find bearing shell combinations that are more even.
I shuffled the bearingas around, until I came up with the best combination of which bearing should be installed around which main journal. See 3rd sticky note (right most note to see the oil clearances.
I then labeled the bearing backs with a scribe to denote which bearing shell should go which journal when I get them back from WPC treatment (B is block side, C is main cap)
Hood Wood Vehicle Bumper Motor vehicle
Then tried out the B series breather/black box delete AN fitting kit I picked up years ago. I had NO idea where these were supposed to go, until I stared at it long enough with a flashlight lol
Motor vehicle Automotive tire Bumper Automotive exterior Hood
Wood Automotive tire Gas Gear Auto part
Automotive tire Wood Rim Motor vehicle Bicycle part
Should work out pretty good with the existing breather/car can.
I'm also ready and setup for tomorrow to measure rod bearing oil clearances with caps torqued and bolts stretched to spec, weighing and shaving the rods, then getting them installed to the pistons:
Electronic instrument Audio equipment Office equipment Desk Circuit component
Then I can gap the rings, install piston/rods to bore, and then get the head bolted on so I can install cams and begin mockup of exhaust manifold stuff.
More fun stuff tomorrow!!
Discussion Starter · #1,263 ·
Love the use of the UNCG sticky pad notes. I'm very guilty of using them this way too. Just got to keep them in order lol.
The entire B series bottom end is now blueprinted on sticky notes haha. Need to transfer all that to a spreadsheet.
Discussion Starter · #1,264 ·
Got a crap ton done today on B series.
Started the morning with a highly inappropriate cup of coffee, and measuring the rod bolt length before torquing/stretching:
Table Curtain Gas Engineering Machine
Gas Measuring instrument Machine Gauge Engineering
Determined the relaxed length of the bolts, established a bolt to rod placement reference schema, torqued them down with ARP lube and recorded the stretch, then determined whether the bolts would require any additional torque on the final install torque to achieve proper stretch.
Handwriting Clock Font Wood Rectangle
The bearings were installed before torquing, so I could measure rod bearing inside diameter with the bore gauge to determine actual oil clearance. The rod bearings torqued in the rods had a perfectly even inside diameter across all the rods, which meant that the rods themselves and any combination of bearing shells could end up in any cylinder on any rod journal, since final oil clearance with all things being even on the rod side will be determined by the crank rod journal outside diameter very slight differences:
Handwriting Font Event Ink Metal
All in all, the rods will have an oil clearance average of .0013", which is perfectly in spec.
Next up was balancing the rods. I performed balancing checks and corrections using two methods, 1) total rod weight, 2) big end weights.
I opted to balance the total rod weight first, and make any big end specific balance changes later. But first, baselining. The total rod weights before corrections in grams:
Automotive lighting Wood Audio equipment Gas Auto part
The heaviest difference was off by almost 2 grams. Even though I did check and measure the weight of the rod bearing shells before doing all this (all of them weighed exactly the same), i opted to balance the rods with the bearing shells installed to the rod, and still torqued down.
Balanced all the heavier rods down to the weight of the lightest rod using the sides of the big end to remove material from. Ended up able to balance the rods to within 0.1g of each other:
Wood Bottle Gas Auto part Font
Automotive tire Motor vehicle Table Wood Gas
Table Cup Coffee cup Tableware Audio equipment
Crankset Tableware Cup Set tool Tool
Table Reflex camera Gas Camera lens Cameras & optics
I set up the jig to weigh the big ends, but turned out that after balancing the total rod weights, the big rod ends measured out to within 0.2g of each other! Obviously the majority of weight imbalance was definitely in the chunkier side of the rod for sure. So no need for further corrections to the big ends, they're ready for install.
Discussion Starter · #1,265 ·
Moved on to balancing pistons.
Checked the wrist pins, they were bang on within 0.1g of each other, so didnt shave anything off of them. Same with the ring packs and the wrist pin locks, all weights matched, so moving on to pistons.
Even though the pistons technically weighed the same in terms of whole grams, they were off about 0.7g lightest to smallest. While I'm there, might as well get them within 0.1g.
The red numbers were the tenth of a gram value, and are the before weight measurement. Got them all cut down to match the lightest weight (top left piston) of 284.1 grams:
Gas Audio equipment Auto part Plastic bottle Machine
Removed the rod bearings from the rods, and have the mains and rods all ready to ship out for WPC treatment out in Cali.
Cleaned, dried and lubed the rods and pistons, then installed them following speedfactory and wiseco specific directions:
Gas Font Water bottle Automotive exterior Motor vehicle
Audio equipment Circuit component Gas Electronic device Auto part
Moved on to measuring and setting the ring gap. Following Wiseco application specific gap factors, determined the 1st and 2nd ring gaps to be 0.018" and 0.019" respectively. Fit, measure, cut, repeat until in spec:
Motor vehicle Automotive tire Automotive lighting Automotive exterior Rim
Tire Wheel Automotive tire Automotive lighting Motor vehicle
Ready to slam em home:
Motor vehicle Wood Automotive tire Automotive exterior Bumper
Automotive engine gasket Motor vehicle Gas Audio equipment Wood
Automotive parking light Vehicle Hood Wheel Automotive tail & brake light
I am so tired of messing with this stupid thing, I will absolutely buy Wiseco one piece ring compressors next time this engine comes apart, in 75.5mm and 81.5mm flavors.
Automotive tire Wood Gesture Gas Automotive wheel system
For some reason, i could NOT get the oil control retainer rings to STOP PREMATURELY POPPING OUT OF THE RING COMPRESSOR PREVENTING PISTON FROM GETTING IN THE HOLE!!! I've never had so much trouble with this ol compressor before, i gave up on it about 45 mins later after STILL NOT SINKING A SINGLE PISTON. This compressor was promptly punted into the woods.
I ended up compressing the rings one at a time BY HAND and getting the pistons to go into the hole wayyyyyyyy easier than using that dang compressor tool!! Seriously, in about 5 mins, the pistons were in doing things ENTIRELY BY HAND.
Discussion Starter · #1,266 ·
Cleaned every single block oiling passage thoroughly with bore brushes, pipe cleaners, brake clean and compressed air. Shes **** (spicc) (really? Sure, spanish/mexican guy derogatory, I get it, but context is everything lol) and span.
Installed the oil control restrictor, cleaned the block head bolt holes, oiled up the studs going down into the block, set them to torque spec, ARP lubed the studs on the head side, installed the Proseal HG, wiped down the face of the cylinder head, and set it over the deck, then finger tightened the head stud washers and nuts:
Wood Motor vehicle Gas Automotive lighting Drinkware
Wood Gas Machine Drink Barware
Wood Gas Engineering Auto part Machine
Wood Gas Engineering Machine Auto part
Had a helper :)
Engineering Machine Event Toddler Hat
Finger tightened the head hardware, and set the valve cover over to cover the valvetrain and spark plug holes. Also test fit the intake manifold, installed the water pump and timing belt tensioner:
Automotive tire Motor vehicle Automotive exterior Automotive design Wood
Automotive tire Motor vehicle Automotive design Automotive exterior Engineering
Will torque the head down when the bearings come back and I'm ready to set the crank in.
· Brokedick Millionaire
I have a ring compressor like that, last person to use it was my son about 20 years ago when he was 12. Dropping used Y8 pistons into my Z6 to replace the melted ones...
Discussion Starter · #1,268 ·
Manifold flange came in. This is by far the best quality DIY manifold for the price point:
Wood Hand tool Revolver Bicycle part Gun barrel
Wood Personal protective equipment Auto part Eyewear Metal
CNC'd recesses for the schedule 10, and proper transitions from the oval ports into the circles. Good stuff from Treadstone performance!
Discussion Starter · #1,269 ·
Little bit of late night work.
Placed the manifold flange on the head with the gasket to see if I'd need to do any matching to avoid restrictions. Aside from porting the head wider to match to the flange, there is no port interference from the flange or gasket at all. I also don't really want to match the exhaust ports for this manifold, since i highly doubt that small step down is going to adversely affect anything. At least it's stepping from small to big, which is correct.
In NA form? Yes I'd absolutely port match. But turbo, and only 350whp at that? I'd rather keep meat on the ports and take the 1.5 whp loss lol.
Automotive tire Motor vehicle Wood Bumper Automotive exterior
Automotive tire Motor vehicle Bicycle part Gas Rim
Motor vehicle Gas Fixture Auto part Wood
Also got the Honed master delete and the modded pedals drilled and installed:
Wood Gas Bumper Electrical wiring Engineering
Hood Motor vehicle Vehicle Automotive design Auto part
Hood Motor vehicle Automotive tire Automotive exterior Automotive fuel system
Saw Hand tool Tool Motor vehicle Metalworking
Bearings boxed back up and ready to send for WPC this week:
Table Audio equipment Gadget Electronic instrument Electronic component
Took the Ishihara Johnson crank scraper out of its box and set on the toolbox, since after torquing rods and mains down in a couple weeks, fitting this guy will be next before bottom end gets buttoned up.
Gas Engineering Auto part Wood Machine
Discussion Starter · #1,270 ·
Cleaned and installed the clutch release bearing, fork, boot and halfshaft to transmission:
Automotive tire Rim Automotive wheel system Machine Wood
Automotive tire Motor vehicle Wood Rim Automotive exterior
Automotive tire Wood Gear Crankset Motor vehicle
Vacuumed out the interior from all the plastic bits that shattered when removing the stock dashboard, and better test fit the PCI dash to see what the end product might look like. I still have no idea yet how I'm going to drill holes in the firewall for the dash nutserts lol, it's TIGHT against the windshield. I'll figure it out hahaha:
Hood Motor vehicle Automotive lighting Automotive design Automotive exterior
Vehicle Car Motor vehicle Hood Automotive design
One thing I really like about this dash, look at how much room for activities there is on the end openings! This is going to be so much nicer to get to stuff at the firewall with less interference with the roll cage!
Vehicle Automotive lighting Hood Motor vehicle Automotive tire
Cleaned up and test mounted a few brackets, mounts and alternator:
Automotive tire Motor vehicle Automotive design Bumper Automotive exterior
Discussion Starter · #1,272 ·
WPC has received the bearings and sent me an invoice already. I paid the invoice, so should have them back next week.
Also ordered a few other remaining B series bits, should have them next week as well:
I don't have many things left on my to-get list for the B series. I anticipate it will be ready for the dyno early March.
Still have a few chassis specific things to get, but not many!
Registration for Hyperfest opens this Friday at 1PM, so I'm jumping on a spot as soon as the page is ready. Also have a buddy from work coming to hyperfest as well, he just bought a 2023 Subaru BRZ, and he's itching to get it on track.
Also, new for this year, talking with @Soul Engineering over the last couple months, I think we're going to spend a few weekends doing drag strip days with Grey car, getting it dialed in terms of engine and chassis mods.
We have a few drag strips near us. Even though its not a drag car, I think it will be a great place for test and tune, to give the new components a shakedown at speed to work out any bugs before the road course at hyperfest.
Discussion Starter · #1,275 ·
ATI damper, motor mounts and treated bearings will all be here by Monday.
Might head out to garage to work on the dashboard and wiring harnesses a bit more tonight. Also might tack together some of the log manifold piping. Will post pics later if I make progress!
Discussion Starter · #1,276 · (Edited)
Hyperfest 2023 slot confirmed!
Azure Rectangle Font Parallel Screenshot
Prices went up 12-15% this year unfortunately.....
Got the PCI dashboard permanently installed finally. I was wanting to wait till I got the dash harness buttoned up, but something I love about this dash that I'll allude to in a bit made me press forward.
First, some words of advice for those wanting to purchase this dash: it is DIFFICULT to drill holes in the car firewall at the allotted mounting holes with the windshield still in the car!! Not saying you shouldnt buy one, but just make sure you have the tooling required to get you through the situation should you choose to try it. It takes some creativity, but its not impossible.
On to the good. This dash is AMAZING for a car going full race car. I can see everything underneath, even when permanently installed. I have full visibility to the pedal assemblies for adjustment, all the chassis harness firewall passthroughs, visibility and access to the harness itself, access to the sides and tops of the steering column still, etc. Its fantastic!
Hood Automotive tire Vehicle Window Automotive lighting
Car Vehicle Automotive tire Wheel Motor vehicle
Hood Automotive tire Motor vehicle Vehicle Automotive design
Hood Motor vehicle Car Automotive design Vehicle
Hood Automotive tire Automotive design Motor vehicle Vehicle
Motor vehicle Electrical wiring Gas Auto part Cable
Motor vehicle Gas Electrical wiring Electricity Automotive exterior
Also fully buttoned up the brake pedal assembly to the firewall and installed the master cylinder pushrod and clevis to the new pedal hole, and got it properly adjusted. Just need to switch the lines over to the new master, and bleed the brakes with the new wilwood fluid.
Discussion Starter · #1,277 ·
Got some more done in the shop tonight.
Tested the mounts to make sure everything was kosher:
Bottle Wood Gas Electrical wiring Hardwood
Motor vehicle Automotive tire Hood Automotive design Wheel
Automotive tire Bumper Rim Wood Automotive lighting
Installed the TB, and finally fixed the one stripped out MAP sensor adapter hole thread where I just jammed a wood screw in there previously to get by, just went ahead and converted both holes to M5:
Motor vehicle Gas Wood Auto part Automotive tire
Gas Machine Coil Nut Metal
Motor vehicle Engineering Machine Nut Gas
Kinda pissed about this, didnt even think about the IAC being different between B and D, but sure enough the holes are spaced much further apart. I'll need to get an IAC:
Automotive tire Motor vehicle Bicycle part Rim Auto part
Also got the water pipe and thermostat housing spruced up and cleaned, ready for orings and new tstat:
Motor vehicle Gas Automotive design Engineering Machine
Motor vehicle Automotive tire Rim Auto part Engineering
Also received the new shift knuckle for the B series trans, so I was able to finally bench shift it, it worked out great:
Pliers Hand tool Wood Tool Metalworking hand tool
