I would think the extra torque will be nice. What made you decide to pull the engine?
Its been something that has been coming for a while. In prepararion for 2023 season, and ultimately setting a roadmap for Grey car for the next 2 years, a new engine/trans is coming this spring.
It's been a goal of mine to run two engine/trans setups in this car, as an attempt to keep the car alive and out on track as long as possible, in a time/resource efficient way.
- Sure building a new powertrain is up front resource intensive, but doing it right the first time, and during off season, allows me to simply refresh normal wear/consumables on a cadence moving forward, to keep pushing the engines and car out on track with mimimal mid season downtime.
- I've also been procuring parts and doing work on and off for the B series for about 3 years now (while keeping the D series my main priority), and its now at a point where I can foot the rest of the bill to push it to completion over the next couple months.
I'm going to run the B series powertrain next season, during that time and next winter, I'll refresh the D for 2024.
The D has been in the car for a long while now. I plan to alternate between the D and B series engines/transmissions on a yearly basis, to have time to run one during the season, and refresh the other in my spare time to get ready for the following season. Following this trend, the D has seeiously passed its expiration for teardown and rebuild, and the B series is up next for a run in the car.
I've learned a ton with the D so far, what its weak points are and what improvements have been meaningful. It has also been critical toward how much I've learned about this chassis and handling characteristics above 130-140mph, and where I need to make changes to improve the chassis itself.
Both D and B engine/transmission combinations are built and will be tuned for similar power levels, roughly 300-320whp for track duty.
- The D is already built and at that power level, and has proven it can play on track dependably in that range.
- The B makes its debut this spring, where I hope to begin tuning it by March/April, with its first event in late April, or Hyperfest in May. The B architecture is just superior to the D series in terms of the amount of abuse it can take before issues arise, and I wholly intend to punish it at that power level in 2023.
All this being said, a yearly maintenance teardown/rebuild alternating cadence will help keep them alive for a while
The D has been all around abused for quite some time as I've used it to iron out a number of issues with it and the chassis so far. I wanted to see what the hard life had done to the insides so far instead of just crossing fingers. This is the first time I've inspected the entire thing with pistons out of block in about 2.5 years, but I now have a good basis for comparison about what to expect in terms of wear characteristics.
After this inspection, I now feel confident that refreshing the D series with basic machine work, new bearings and rings, will give me trouble free use for the entire 2024 season with my right foot matted to the floor.
