Brake controller installed to truck, verified all wiring to 7 way at bumper is sound, and has 12v (40A) and good ground back there too!
Almost finished with heavy cable work for battery cutoff and alternator reroute. Cables made for interior switch:
Alternator cable spliced, lugs crimped and soldered, and bolted through with nyloc nuts:
Rear cutoff switch cables made, run to battery positive, and lugs crimped, soldered and bolted to main cable run to front of car:
Interior switch panel mounted back up to be wired in to main cable run, again the connections will be lugs crimped, soldered and bolted together, then covered with good heat shrink with the glue inside:
Also finished running the inside fire suppression cable:
More to come! Had to take a break for lunch, starving and it is hot as balls outside with no shade or fan lol.
