So on to crankcase vent hat V2 lol.
My original boxy shape didn't account for the battery cutoff switch mounted against the cowl once the breather box waa installed in its home, since again I prototyped with a part off the car lol, left that detail out.
So I changed the design, this time hugging the breather filters tighter on the backside, with a recess to allow clearance for the cutoff switch.
Drew up the rough overhead sketch from the looking down viewpoint with some quick measurements, then printed just an 8mm extrusion hollowed out example so I could see how it would sit down over top of the filters and clear the switch:
Worked pretty good! The design is still going to be a two parter, since I couldnt fit even the slimmed down version within the print space on this printer.
Got it all drawn and rendered, with nipple on the right side for the silicone coupler, and the tongue and grooves. You can see the two fit together in wireframe view:
Printing now, it will take all night lol:
Tomorrow looks to be a shite day, with high winds and like an inch of snow, but is supposed to be clear by the afternoon, so hopefully I'll be able to get back on Grey car.
Still need another 5 M8x1.25 helicoil inserts, only have 4 on hand in the shed. Will make a trip to the store at some point so I can finish getting the turbo mounted.
I did put 8 gallons of 93 in the tank as well, we're getting closer!!
