91 civic dx sedan
ok so I know this isnt a honda but you guys are a welth of knowledge my cousin has a 85 chevy monte carlo he just bought its a 4..3 and the fukked up thing is when he bought it it ran fine 2 days later it wont start so I check the engine bay and find out that his distributor isnt tightend down so I turn the dizzy alll the way counter clockwise and the car fires but wont run know i know his timming is fukked so i have to pull the dizzy and set the engine at TDC is there anything special I should do once I put the dizzy back in ?? thanks in advance :beer: :beer:
91 civic dx sedan
come on guys rep for any helpful answers
D-series Janitor
Front Engine Dragste
If it ran, just check it with a light. I would imagine somewhere around 10* BTDC is probably good for initial.
The cam timing isn't easily adjusted like a hondas is.
91 civic dx sedan
no its not running
stock sedan
TDC to start then drop in ur dizzy pull out the ol timing light adjust from there,but if it happens again you might want to look at a timing set replacement(could be slack in the chain or a slightly chipped timing gear tooth)
