1988 Honda CRX
I have been doing some research the last few days on the best way to manage fuel during boost, and have a few noob questions I wanted to ask.
Lets pretend that each question is regarding an obd0 crx or a obd1 civic coupe:bigok:
First, if I were to use a AFC like the apexi SAFC, is that all I would need to tune the car, or would I still need injectors? I know the AFC can tune the fuel amount at set RPM's, but how good is it for turbo tuning?
Second, If i chipped my ecu, would I still need bigger injectors/ can I do that with an obd0 setup?
If I can just go with a AFC it seems like the easiest method. I want to try and not replace the injectors if I dont have to, but want to do the simplest and best method. Chipping ecu's is really easy, so If i can just do that and then get it tuned that would be a piece of cake. But I know that the SAFC tells you a lot of info about whats going on in the engine. Would it be worth buying anyway?
Also what about getting a AFC, and using a rising rate fpr? Is that a decent method?
Sorry for all the scattered noob questions, but Ive read so many threads on this stuff, and none of them answer any questions in A way I get. Thanks.
Hi hater!
lol where do I start.......Well your best bet is to get the ecu chipped and get some DSM450's atleast there a dime a dozen. That AFC shit is just that shit. Old technology and thank god its been replaced with much better stuff. If you want to stay obd0 then run turbo edit or bre and if you go obd1 the possibilities seem endless of the great stuff thats out there. So do it right the first time and stop cutting corners it only leads to a half ass boosted car that wont last long....
1988 Honda CRX
So AFC is shit? LOL, k well chipping is easy, and I know I can pick up 450cc dsm inuectors cheap, and they seem easy enough to install. Do I need a different resistor box on a obd0 car, im pretty sure I read that I dont. As far as tuning all I need is to chip it, get a basemap, and then get it dino tunned? That seems way too easy...
Friend of the D
http://d-series.org/forums/forced-induction/102717-read-if-your-thinking-going-turbo.html
Same resistor box and it is pretty much that easy if you have someone else tune it. Check my posts on the second page of the above thread for some more info.
98 Civic EX
easy to say, not as easy to do...chipping and tuning a car is like saying "all i have to do is run the wiring under the carpet here and i'm done", its never THAT easy, but not necessarily difficult, see what i'm saying?
Friend of the D
Agreed, I should note that you should have a competent professional tune it. It's very easy to mess things up if you don't know what you're doing.
1988 Honda CRX
for sure, i wouldnt do it myself, but ive chipped ecu's before with a basemap, and never got the tunned, so basicly all I need to do is figure out how to install injectors and then take it to a professional.
What do shops generaly run for a dyno and a chip?
98 Civic EX
that varies greatly depending on your location, who you know, have many pulls, and what company is doing it...typically it could run from 50-200 dollars pending
