1 - 12 of 12 Posts
formerly Kit88
What is the best a/f ratio on idle for a tubocharger car???
I already install my AEM UEGO and reads between 14-15 on idle with the engine cold
What's the afr when its fully warmed up on idle?
Thats not horrible..I idled in that range.Some people even go leaner,but im not telling you to do that of course lol if you don't feel comfortable with it.
This isn't the end all way to set up your afrs but its a good guide
I personally shoot for:
15.5->14.5 lil or no load...light cruising, idle etc
13s on high load, low rpm
12s on high load, low vac (not quite boost...or flooring a N/A motor)
11s in boost (or 12s, depends on your timing)
Remember, your timing is more important to get right, but shouldnt be done until after you set your afrs.
formerly Kit88
Thanks guys, I´ll checking this, I´ll try to not drive the car on boost till it get tuned, hopefully tomorrow.
i'm in the uk, so have better fuel.
But i run 16.5,
15 at light load.
14 at medium load. 0psi
13 at 2psi
11.5 at 9psi
11.4 at 9psi on vtec.
But, i think i'm on the limit apart from at full boost.
its all contingent on the variables of your setup... timing, pistons, c/r ratio, etc... on my previous setups i tuned so the higher boost portion had a richer fuel map.. below 8 lbs was 12:1 above that was in the high 11:1 range...
the MAD scientist
If you're running an appreciable amount of boost on cheap 89 ocatane stuff you should be in the low 11's. And don't forget to pull enough timing. Check your plugs often.
1 - 12 of 12 Posts
