1 - 9 of 9 Posts
Hey guys, so for this turbo setup im thinking of running i was wondering if the A/C has to go forsure of weather i can keep it or not.. My summers here get to +38 celcius some days and i really need that! but is there any turbo mani's that will encorperate the A/C into the turbo setup so i can keep it? thanks for the help!
Honda
you will need to get a log manifold. You can get them on ebay, which i wouldnt reccomend because they have terrible wastegate placement. Check out ccfabonline.com
i got my manifold there (not a log though, its a miniram) and i am very pleased with the product. i know lovefabe also makes then but they will be a bit more expensive.
There are some cast iron manifolds and like he said above, log manifolds for around 100 bucks or so, peice together, and there is a guy on ebay selling cast manifolds that are a/c compatible, ill get the name for you later, i beleive he is in Oregon. Heard about the cast manifold from someone in town with a turbo 94 hatch and it clears just barelly, but doable.
Log, Cast... either of them mani's will work for an AC compatible turbo setup... and either one of them will work for 400+ whp, but a tubular design will net 20 or more hp extra. If you can find a tubular, AC compatible turbo manifold... you'll be set! Then you'd only have to find some sort of heat shield for your AC lines so the radiant heat doesn't reach them...
You can keep the a/c if you get the right mani, but I took mine out cause I kinda had to plus im a clean engine bay whore LOL!!!
This is the one i'll be using....
1 - 9 of 9 Posts
