1 - 4 of 4 Posts
I know how to remove the bracket but my question is do I need to plug the holes because the bottom 2 bolts that came out are covered in oil but nothing leaks from the holes.I know this sounds like a dumb question but I've searched and couldn't find much of anything to answer my question.I just want to be sure I can just take the bracket off and it will be fine.
The motor is a D16A6 in a 90 std hatchback if it matters.Thanks in advance
honda/firebird form.
better plug them up because those hole lead into your oil pan.. you will loose major amounts of oil when you hit your brakes.
jk.
there just dirty oily bolts
thats what I thought,thanks alot
jk.
This is the kind of response I was expecting for such a dumb question. I thought it would be fine just wanted to be sure.I appreciate the response
1 - 4 of 4 Posts
