1 - 13 of 13 Posts
What manifolds will allow me to keep and work my A/C. I just picked upa hf manifold, can I use this and possibly put my fan on the other side of the radiator?
is it possible to orient the turbo compressor wheel on one side or the other of the turbine housing?
Turbo Manifolds
Normally, HF manifolds are not the best solution when trying to retain A/C and Power steering. Unless you are making your own adapter plate, you are pretty limited in the configuration of the turbo. Most adapter plates we have seen, are pretty "lined-up" in their arrangement, with little or no offset or twist of the turbo.
You don't really say which bodystyle/engine combination you are working with, so I can't offer much more than that. If you are working with an 88-91, then lots of creativity will be required to retain aything, and you'll probably need to switch to a half rad if you want to run something big.
We just finished a project in an 89 CRX, using an A6 / Y8 / Vitara / 14B / HF combination. We retained the full rad, but lost A/C.
If you are working with a 92 - 95 then you'll have quite a bit more room.
It's probably best to build you own log manifold, and get the placement just how you want it. A lot more planning, but a lot better result.
Hope that helps!
Craig
DIY Log Manifold Kits
1 - 13 of 13 Posts
