1 - 7 of 7 Posts
I have a D15Y2(Middle Eastern Specs, 9.0:1 CR, 134mm Rods), and was looking for a budget rod/piston setup, all i have found was some Crower rods which costs alot for my goals. Can you guys tell me other brands that sells D15 (134mm) rods? Also, was thinking of the Vitara pistons upgrade but i thought... if people use Vitara's to kinda lower the CR... then i don't need to worry about this cause i already run with 9.0:1 compression. again guys, your thoughts?
your advice is appreciated :TU:
That's right... WE don't have D16's around here, we used carbed D15's since 1989 in CRX's, all the way through year 2006.. in 7th gen Civic's(my car)!!! ain't that retarded??? anyway
I'm stuck with the D15, so i'm facing the reality here, i'm happy with my 9.0:1 CR, and happy with a 27 mm piston compression height :)
And i'm thinking of just throwing rods in there, since i have lower compression then most D's...
1 - 7 of 7 Posts
