1 - 4 of 4 Posts
04 Subaru
Ok, So doing a Z6 swap in my 99 coupe, and I can only seem to not find to much about these lines. I have read a bunch on the z6 swap..but most people talk about using the Y8 intake manifold.
I got the car with no motor....So I am using everything from the Z6.
My first question...This little sensor with vacuum line coming off it...where should it go. Its on the back drivers side of the intake manifold.
Second question, Should the line from the throttle body just go to the purge outlet on the Charcoal canister?
Thanks for looking.
le google bro
04 Subaru
le google bro
I googled it man, but that canister doesn't match mine at all. Thats the canister that goes with the D16Z6..I am using the stock 99 canister. Doesn't have those connections.
It only has the one connection in my pic in my first post.
04 Subaru
Discussion Starter · #4 · (Edited)
This is the stock setup on the y8...If...If I am thinking about this right, I can use the purge valve on the Z6 manifold, and than I would just cap the fitting on the throttle body. I was trying to find a for sure picture of a y8 throttle body, some pics I found had that metal nipple on it, some didn't. So I wasn't sure exactly what to do with it.
1 - 4 of 4 Posts
