1 - 3 of 3 Posts
Ever wanted to change your interior instrument lights (the ones with the turn signal indicators, engine check light, seatbelt light, etc.)? Those are located right next to your analog speed meter, gas meter, tach, etc. right in front of the drivers seat.
I made this specifically just to add a VTEC light indicator to my car, but i decided to go ahead and make it so that you can totally customize your instrument lights. This is provided in a .FLA format, meaning you need Macromedia Flash 5 or Flash MX to open the file. If you need it in .BMP or .JPG format, you can do that yourself, provided that you have Flash 5 or Flash MX. I didn't provide a .BMP or .JPG format, because it is easier to fully edit it in Flash, then to use Photoshop. Feel free to make any changes you wish and complete instructions can be found when you open the file in Flash.
other than Flash 5 or Flash MX, you will need WinZip or some other zip utility to unzip the file after you download it.
http://sxng9.tripod.com/civic_instrument_light.zip
S
have someplace else this is stored? Tripod is gh3y and wont let me download it.
im a t00l. . . just had to copy and paste. . . duh.
1 - 3 of 3 Posts
