1 - 7 of 7 Posts
1990 Honda Civic Si
Hey ive got a 1998 Honda Civic Si (EX). The speedometer and odometer dont work. The speedo stays at 30 kph (20 mph). It will sometimes work, its on and off. I had it diagnosed and i was told that the ground wire going to the vss is bad. Im just wondering how i fix the wire? Ive got a haynes manual with the wiring diagram, but im not sure how to check where in the wire is broken? Any help would be great thanks!
*Its a D16Y8 btw*
Easiest way to check would be with a voltmeter. You would check the black wire on the sensor harness and the ground wire next to the thermostat on the engine. If you have continuity then the wire is fine.
1990 Honda Civic Si
I already know that's its the ground wire, I just don't know how to fix it. How do I find where the wire is broken?
Your not gonna find the brake in the wire by looking at it. What you can do is cut the ground wire and soider a new wire to it and ground it to the thermostat housing.
1990 Honda Civic Si
Discussion Starter · #7 ·
Thanks, I cut and soldered I new ground on and it's working now!
1 - 7 of 7 Posts
