My 96 Civic HX slung a rod through the crankcase yesterday. I can't find a replacement engine locally, so I bought a D16Y7 engine, instead of the Y5. I want to know if I can put my Y5 head on the Y7 engine, so I can keep VTEC.
Discussion Starter · #2 ·
My second part of the question is: The Y7 block I got from the junk yard has 155,000 miles on it. Would my recently rebuilt Y5 head cause the rings to blow on the Y7 block?
Altima
i think it's called a mini me swap. lol. it does work though
i would do a rebuild on the y7 block though...might as well if you have the money and time so you don't have to do it later
Altima
according to this site you should be fine
*EDIT* I know i'm a n00b here too. but google/search is really your friend here. unless you're wearing a flame suit though
*EDIT AGAIN* not a n00b anymore!!! but i'm still a n00b in dealing with cars
did you just ask if the Y5 head will cause the Y7 rings to blow?
forgive me, but HAHAHAAHAHAHAHAHAHAHAH
sorry
no it wont blow the rings if everything is in good shape. the only way the Y5 head will cause the "rings" to blow is if the ehad allows coolant/water to enter the combustion chamber, even then the rods will go first
