hi guyz i need some help ...
ive done the rear disc conversion on my 96 4dr non abs civic ....will i need a brake prop valve , brake booster & master cylinder to finish up. in uk 96 civic with rear disc are mainly abs ek4 . we dont have the 96 - 00 si you guys mention so the mc /booster and prop valve is out of the question . so can i use the 92 - 95 civic 30/30 prop valve ,master cylinder 15/16 and booster ?
the 92 - 95 e-brake cables they also work fine without any modification.
