1 - 16 of 16 Posts
civic coupe
115 + shipping
kyb NON adjustable struts
cheap coilovers
coilovers arent the best brand prolly dropzone or R1 something? the ride is "decent" a little bouncey at higher speeds if you hit a bump....
ill get pics up when I get new Tokico HP and new springs installed
Would those work on a CRX?
If you swap the "forks" at the base of the strut you should be able to swap them over. The difference in the 2's suspension height is all in the forks, swap em' and you should be okay!
civic coupe
Discussion Starter · #8 ·
the front coil sleeves are on the struts pretty good i dont want to damage them by trying to get them off so purchase comes with strut and coilovers you'll need to use your own upper piece and everything bump for cash buy them up!
1 - 16 of 16 Posts
