1 - 3 of 3 Posts
I recently converted my car to manual steering and have the complete system for sale includes: looking to get $200 for everything no partout, located in Gastonia, nc NO SHIPPING will meet up to 1hour away!
Power steering bracket for b7, Dont know if there is a difference?!
PS pump
belt
ALL lines, resiviour
fluid cooler (mounts infront of the air conditioner radiator)
ps rack and pinion complete
bolts
AND THE SUBFRAME!!
*The only thing missing is the fluid and 4 bolts used to bolt the rack to the *subframe( I had to reuse mine, but you can also reuse yours!)
*A new driverside boot for the rack will be needed because it is torn slightly
Will post pics today!
Discussion Starter · #2 ·
Includes everything is pictures!!
LEFT to RIGHT:
Brass bracket is for the resivour, black bracket is to bolt the rack to the subframe,Pump and bracket,Belt, bolts inside of belt are for the lines to the chasis, fluid cooler, Resivour and hardlines
SAME as above
Notice all the bolts are included to the bracket and pump!!
This is the driverside boot the lip is torn off of it
Subframe and rack&pinion
Just reuse your two of the #24 & 27 & 25 and one # 15 boot is needed but not necessary
1 - 3 of 3 Posts
