Hi, I just put together my turbo d16z6 build and did my first start. The engine cranks right up and idles just over 1000 rpms cold. Sounds healthy too. The oil light goes out when the engine is started. Just want to know if I will get an oil light if the oil pressure is too high? Reason being is that I have a digital glow shift gauge that’s hooked up to my oil sandwich plate and it’s reading 94psi constant on a cold start. I do have and acl race oil pump installed. Thanks
I would check with a different gauge, 80 psi is normal for cold start up. It's what the bypass spring is rated at.
