1 - 3 of 3 Posts
Hello, I am looking for some assistance in finding the correct length shaft for my vehicle.
I bought a new replacement steering column part from ebay which was listed as #53200-SR3-A02. However, it is too short. I have attached pictures. When I line up the mounting points and the steering wheel side, you can see how much shorter the shaft length.
When I check hondapartsnow, I only see 2 columns listed. One lists Mfg. Origin: USA and doesn't state "tilt". The other one list Mf. Origin: JPN and lists tilt. However, 53200-SR0-A02 lists "replaced by: and tilt 53200-SR3-A02. So I was assuming they were both interchangeable. I checked auto tranny, DX, LX, and they all list the same part numbers.
https://www.hondapartsnow.com/parts-list/1995-honda-civic-4dr_dx-ka-5mt/steering-column.html
Does anyone know what part number is longer or if I just got the wrong part delivered? Is there a way to get the exact measurements for each part numbers so I can compare.
My vehicle is a 1995 Civic, 4 door sedan, 5speed manual, tilt steering, power steering. Let me know if this is not the correct forum for this topic.
Thank you in advance,
Ryanman
Pull on the shaft, the collapsible column, is collapsed.
Thanks Bone! I pulled really hard and it finally expanded (popped completely off). I put it back on, adjusted it to the correct length, and installed it. You saved me again! Thanks so much.
1 - 3 of 3 Posts
