1 - 18 of 18 Posts
94 si hatch
hello there guys made this post bc this heat is no joke i think i almost had a stroke the other day lmao no laughing matter so i went out and bought me a ac kit i got a kit for 99 si but im not sure what fits and not i know the condensor doesnt not fit for a 94 si i do have a b16a with a p30 ac bracket, im fixing to return my condenser and get one for a 94 can anyone tell me if the dryer and the expansion valve are the same on eg and ek since i bought for a 99 civic si and not a 94 civic si
also is the tensioner bracket the same in eg and ek???
thanks for your help!!!
You need every thing from a 94-95 civic except the ac compressor and bracket. The compressor and bracket need to be from a b-series. The two rubber hoses I forgot what works,I think I used the stock 94-95 rubber hoses and modded them a little to make them work.i might have used the rubber hoses from the del sol that has the b16 in it.
94 si hatch
hmm i see okay well im gonna go exchange that kit tomorrow if theyre open if not i have to wait till monday :/ is there any difference on the d and b series compressor colder?
94 si hatch
anymore input on the rubber hoses that run from compressor to condenser will be appreciate right now i got the original eg ones (d-series)
I never tried to use a d-series compressor on a b-series. Maybe I should have as it would of made it easier,but there might have been a reason i didn't use the d-series compressor,I just can't remember as its been like 10 years since I did it. Thinking the d-series bracket might not bolt up the the b-series block could of been one reason.
The hardest part was the rubber hoses. Trying to get them to fit right was a pita.
94 si hatch
fudge yea bc i have a bseries compressor and when i got the lines from an eg ex they dont fit perfectly so im gonna look into those that came with a del sol vtec, should i just get the kit for that del sol?
Iirc one line fits fine it's the other one that needs to be modded a little. I think it needs to be bent/turned a half a turn,something like that. I can't tell you for sure cause the hoses I used I got from different people that really didnt know what they were for. I just picked what I thought would work best and made it fit.
The bottome part of this line needs to be bent so it will bolt to the compressor.
94 si hatch
iirc is the name of brand?
94 si hatch
and thanks a lot for input cant wait to roll with ac on lol
94 si hatch
damn ok that one looks like integra hose
Iirc=if I remember correctly.
Meat Popsicle
91 CRX Si
Threads like this always make me want to start my thermoelectric-based AC project up again. If only there was a way to keep the current draw down:/
Wouldn't a kit from a Del Sol VTEC match right up?
Black/Green Civic HB
How big of Alt. you gonna run for those therm. Coolers?.....jk.
I always think a/c is over rated, after all day in the heat you might as well stay in it ;)
94 si hatch
Discussion Starter #16
dude yea its been 109 the past 2 days wtF?
I pulled ac from my sol and live in tx.. Don't care that's why I drop the windows lol it's been 107ish up in north tx. I can easily convert back since I had 2 donor sols but meh that'd just drag down my motor
ej8
yep that good old Tx weather, my ac works but on the streets its crap. i need to wrap my headers so they dont heatsoak the condenser. IR the temp and got 400-450degs venting from the headers.
So i do feel your pain.
Crazyness. MY del sol had ice cold ac and i love it even tho it only had a d15b7 and was slow.
And Windows down in traffic with 104f heat and no wind does not cut it at all.
1 - 18 of 18 Posts
