1 - 20 of 28 Posts
same
Finally getting this put together. I have a ton of parts that need to go. Will get shipping quotes as soon as I can. Reasonable offers please. No Lowballing will be aceppted.
pics will follow this post.
z6 intake manifold: 75.00
56mm TB: 20.00
IAC valve 45.00
z6 cam gear 20.00
z6 water pump 20.00 (only had a few hundred miles on it when I disassembled the motor)
z6 oil pan 40.00
z6 oil pickup 10.00
z6 crank timing gear 10.00
vtec solinoid 45.00
civic ac compressor 80.00
94 ex power steering pump 25.00
z6 alternator 45.00
manual driveshats left and right 45.00 each
radiator fan 20.00
ac condenser w fan. 30.00
power steering bracket 5.00
ac bracket 10.00
engine to Trans mounting brackets. 10.00 for the pair
motor mount bracket timing belt side 5.00
z6 valve cover 25.00
z6 crank pulley 20.00
z6 timing cover set 25.00
ac box under the dash 60.00
Air bag driver side 40.00
Air bag passenger side 40.00
front drivers seat 65.00
front passenger seat 65.00
rear seat set 75.00 (coupe)
seat belts Lf,Rf,RR,LR 15.00 each
coupe door panels 20.00 each Left and right
Center counsel set. 25.00
Jdm cup holder with coin tray 15.00
coupe headlights OEM 20.00 each
Left corner marker light 10.00
Front calipers with brackets LR 30.00
front shock forks 15.00 each
clutch master cylinder with resevoir 20.00
slave cylinder. 10.00
Z6 pistons with connecting rods (caps may have been mixed up by accident) 10.00 each
ex coupe gauge cluster 45.00
Z6 engine harness ( untouched, no mods) 60.00
I will update this post if I missed anything. if there is a part you see that doesn't have a price I'll add it. thanks guys!
same
Discussion Starter · #2 ·
Z6 water neck 5.00
z6 thermostat housing 10.00
z6 water pipe 5.00
same
Pics
same
Discussion Starter · #4 ·
more pics
same
Discussion Starter · #5 ·
some more
same
Here's more
same
Discussion Starter · #7 ·
even more
same
Discussion Starter · #8 ·
and more
same
Discussion Starter · #9 ·
more more
same
Discussion Starter · #10 ·
more more more!
same
Discussion Starter · #11 ·
and more!
same
Discussion Starter · #12 ·
and more..
same
Discussion Starter · #13 ·
seats!
same
Discussion Starter · #14 ·
Also all of these parts came off a running car and everything is in good condition and works
Reactions: slo_eg8
same
Discussion Starter · #15 ·
Bump
same
Discussion Starter · #17 ·
Block head and crank. all matching. block comes with matching girdle.
same
Discussion Starter · #19 ·
Head is complete so it's 125. block is 75 and the crank is 80.
1 - 20 of 28 Posts
