well i bought from a buddy of mine a 93 stock d15b with a t25 turbo 8 psi side mount intercooler.. my question is could i go with a front mount intercooler witch is bigger in size and have to change the pipings without re-tuning the car or will i need to do a re-tune thank pics soon
its just cooler air going into the turbo not diff in psi same amount off psi will be being pushed into the engine just bigger is cooler air so I'm on debate for that
Depending on how efficient your older setup and your newer setup are, it could either be fine, or you could kill the engine. Any time you change major components, you need to at least monitor your AFRs. Ideally, you would want to datalog before and after the changes to see how effective the changes are.
Thank steven for the pics i want a front mount inter cooler so just put a wideband on and moniter to make sure afrs are good and not to diff
