1 - 20 of 337 Posts
civic coupe
Block Work
Y8 block.. hot tanked.. honed.. bored .020 over.. decked..micropolish & balanced crank
Stock sleeves
Block guard
SRP 9:1 pistons w/new rings
Eagle rods w/ARP bolts (block notched)
Cleveite race bearings
OEM gasket set
G.Y timing belt
Ported oil pump
Oem water pump
New rear main seal
Head Work
Full port n’ polish
Copper valve guides
KMS springs and retainers
Omni Power valves
Zex/Comp 105300 cam
ARP head studs
OEM head gaskets
TURBO PARTS
T3T4 turbonetics 60/63 trim stage3 exhaust wheel
Lovefab ramhorn manifold
Speed shop 5 bolt flange
Tial w.g w/dumptube
Apex-I 3 inch exhaust
Custom 3 inch downpipe
Ebay FMIC and radiator
Custom made mandrel bent I.C piping
PerformerX intake manifold
Thermal Intake manifold gasket
LS 60mm throttle Body
PTE 880cc injectors w/new clips and resistors
AEM fpr
B&M fuel pressure gauge
P28 tuned on crome
obd2<obd1 harness
Blitz dd BOV
Golden Eagle Vac. Mani.
MSD cap, ext. coil, wires
Stealthmode oil line kit
Fatt dc turbo timer
B&M short shifter
type-r knob
XTD stage 4 un sprung clutch
LSD motorsports 12 lb flywheel
Innovative 60A street motor mounts
Autometer water temp, oil pressure, volts, boost, a/f gauges
SUSPENSION SETUP
Buddy club N+ full coilovers
Suspension techniques 19mm sway bar
Omni power LCA’s
OEM 99-00 civic strut bar
Rear tie bar
Rota C-8 wheels w/toyo tires
IN THE MARKET FOR….
Greddy profec B2 boost controller
OBX LSD
Slicks
traction bar
Im MOST LIKELY going to attempt to put the long block together tonight along with bolting the intake mani and the ramhorn and turbo all together tonight then I just have to wait for motor mounts and the LSD to really start the install. A little more needs finished with the wire tuck! IM POSTING A SHIT TON OF PICS UP WHEN I GET HOME GOING TO TRY TO GET THE CAR OUT IN THE LIGHT HAHAH
Im sure im missing crap il edit as need or as bought!!
1.8 nawz powa
Block Work
Stock sleeves
Block guard
OEM gasket set
G.Y timing belt
Ported oil pump
Oem water pump
New rear main seal
Head Work
Full port n’ polish
Copper valve guides
Omni Power valves
Zex/Comp 105300 cam
ARP head studs
OEM head gaskets
TURBO PARTS
AEM fpr
P28 tuned on crome
obd2<obd1 harness
Blitz dd BOV
Fatt dc turbo timer
B&M short shifter
type-r knob
SUSPENSION SETUP
Omni power LCA’s
Rear tie bar
IN THE MARKET FOR….
OBX LSD
Slicks
traction bar
"Cough" Copy Cat "Cough" haha. Looks sweet dude. Im about to get back on mine now that I have my tranny working.
97 GSX-R 750
What's the Carbon Fiber in the title for?
1 - 20 of 337 Posts
