1 - 14 of 14 Posts
civic hatch
the only differance is the 02sensor the vx is 5 wire and the si is 4 u will need to rewire it i think theres a sticky somewhere.the vx already has vtec wires cuzz hello its vtec do some searching im sure you will find it
Why do you want to change harness? Im using Vx harness in my Vx on Z6 motor w/ out any problems..
NeonPinHead said:
not possible... you'd be getting error 41 because the o2 sensor wiring is different. so try again.
Are you serious?? You dont know who you are talking too.. Of course thats rewired.. But that dont matter anyways because I tuned my car w/ Chrome and disabled the 02 sensor anyways because I am running wideband to monitor..
NeonPinHead said:
but you had to modify the stock VX harness in some way for it to run the Z6. you can't just drop in a Z6 plug in the P28 and have everything set.
Yea you can, if you burn your own chips :) Even if you just ran stock P28 all you would get is a CEL for 02 sensor which your car will still run, just on the rich side alittle..
1 - 14 of 14 Posts
