1 - 2 of 2 Posts
Does anyone know if there is a difference with engine wiring harnesses for auto or manual. I have my stock b8 wiring harness on my b7 motor now but, have another wiring harness for the b7. It was an automatic. The only difference I see is the map sensor plug for the b7 is a two wire. The b8 is a three wire map. Any help would be greatly appreciated. By the way my cx is a manual.
Discussion Starter · #2 ·
I solved it. The auto engine wiring harness will not work. I took my original b8 wiring harness and wired in the 4 wire O2 sensor. Working like a champ. I did a little research and found out that the auto wiring harness was totally different from the manual.
1 - 2 of 2 Posts
