Thanks guys!!!
Really need a wiring harness now. Wires on this one are old and breaking.
Thanks man! As for wheels and tires, I have no idea. For money's sake, I might just paint the spokes on these gunmetal and rock them for a while. I hate em, but they are functional and in really good shape....really light weight too.like it!
so what wheels and tires are you considering?
THANKS!It's awesome to see a farm car so clean. What coilovers are those though and how's the ride with them
Ill take a picture tonight after work, but if youve seen the two keys on the back side of the distributor that engage the slots in the cam, one of them is broken off completely, and the other is broken in half.....Ill snag a picture tonight though.pics of what your talkin about please .....
..... when the motor is at tdc take cap off and put rotor at 1 and you should be good to go
x2Lol, looks like someone dropped it or forced it into the head 180 off. It takes very little power to turn, so the tabs are needed more for keeping it accurate.
You can remove the circular retaining clip around the middle, slide the pin out, and replace it with another obd0 distributor's "donut". They may even be the same as an obd1/2 unit, but I wouldn't count on it.
Important: If you look at it closely, the centerline of the tabs are slightly shifted off the centerline of the distributor shaft. There is the machined line on the 'fatter' side, and someone used a sharpie to note orientation previously. When I insert it, I take the cap off and spin the rotor until it slips in. I get it very close so it takes half a second.
