91 Hatch back with a D15 DPFI So I was driving and my car cut out. Took the distributor cap off and the coil was fried. Replaced it with a brand new one car started for about 5 minutes went to drive off and it cut out again and now it wont start again. Cap is dirty cleaned off the contacts. Battery wont hold a charge. And it cranks but stalls for a second and the n continues cranking while its being jumped any ideas??
did you get a code?
if not i would check grounds
as for your battery not holding a charge i would make sure you dont have battery acid on or litteraly in between the strand of you posetive or negative wires to your battery
GROUND!!! same shit happend to me. check the main one leading of the valve cover then the transmission ground. also your alt ground. if your battery keeps dies your alternator might not be charging casue of a shit ground and there for it is draining your battery. grounds>everyone lol
