61 - 67 of 67 Posts
1991 Civic DX
Discussion Starter #61
I wrote a Long reply back in December, I'm not sure if I forgot to hit the submit button (I was very tired when I wrote it). Hopefully I'll get it right this time.
Recap:
I welded up my exhaust in early august. It sounds so much better than before, and I can hear my stereo again. I really like the thrush turbo muffler with the resonator that I got with my exhaust. My one gripe: the Ebay header I bought (DNA Motoring) hangs just a bit lower than I'd prefer, and scrapes on tallish speed bumps. Currently I am running with a cat delete, Once I get the new motor in I'll install the cat I have already bought.
I found a donor car: '98 LX Sedan (D16Y7, Auto Transmission).
They sold it to me for less than scrap. :clap: It was running and driving, seller was selling it because it was rusty and the rear brakes were having an "issue".
I bought a Y8 manifold for the D16.
I had a harness built to adapt d16 obd-2a to EF body, add mpfi and upgrade Obd-0 to Obd-1 (P06).
New:
I've been keeping an eye on a Civic Wagon on youtube. Its called the war wagon :tank: , check it out on the honda rescue garage channel.
The guy makes lift kits and sells them. Over Christmas he had a pretty decent sale and I bought some 1" spacers for the front and some 1 1/2" spacers for the back.
Along with those, I plan to use the EK struts from my donor car. And I am going to flip the rear lower control arms to achieve lift. My plan is to have some ridiculous rake. I will post some pictures of the spacers soon.
I bought a set of truhart rear upper control arms that are adjustable.
I am still doing my research into the front upper control arms for camber adjustment (any advice will be appreciated).
I've decide I will only use the 1" spacer on the front and hold off on the struts. from what I've read 1" lift shouldn't create a camber issue.
I need to crawl underneath the read end and decide if I need to replace the bushings while I am in the neighborhood.
When I do the lift I plan to write it up in a dedicated post.
I've been stripping the donor car of all its goodies and have been selling them on ebay. With the proceeds I just bought my P06.
1991 Civic DX
Discussion Starter #63
Update
My d-16 is about 1/3 done. All I have is the block work left to do.
I put a brace between the rear strut towers.
Needed a head gasket at 240k in my d15
And Stage 1 of my Lift!! 1.5" spacers in the back 1" in the front
1991 Civic DX
Discussion Starter #64
Rear suspension is done. '98 civic rear struts and 2" spacers. It measures just shy of 31.5" from the floor to the wheel well.
135454
135449
135450
135451
135452
135453
1991 Civic DX
Discussion Starter #67
Fantastic! Did you build the cage, buy it, or have someone else do it?
I bought a jegster roll bar for 92-95 civic off jegs.com, it was cheap with free shipping I paid less than $250. I did all the welding myself, I had help with placement and bracing from a friend who used to do figure 8 racing. The brace between the rear wheels is very recent and highly recommended. I makes a huge difference.
nice ground clearance ..
Thanks, I'm going for different with this car. I've been looking around allot. Saw some youtube videos and joined a lifted honda group on facebook. There is so much info out there.
I went with EK struts front and back for stiffer ride and the additional height.
I have a 1" subframe drop front and rear to it doesn't make the geometry too crazy.
2" strut spacers in the back and 1.5" spacers for the front.
After I finish my d16 rebuild I'll get the front suspension in and set.
61 - 67 of 67 Posts
