1 - 11 of 11 Posts
I am trying to fix my buddies trans for him, first time in this deep. He says it feels "scratchy" when shifting gears. I have measured reverse fork/shift pin, reverse fork/idler gear, shift fork/syncro sleeves, 3rd/4th shift fork/shift arm b. All measurements are within spec besides the reverse shift fork/shift pin. My question is about the syncros, is this the reason the shifting is not ideal?
The inside look great. I can snap some photos if needed. But from what I can tell the majority of the wear is on the outside.
the inside part of the synchro is the "business end"
the ridges should be razor sharp.
Thanks, I will look closer into this. I will post pictures once I have ambition to go out into the cold. Sometime today...
*edit* Using Penzoil Syncromesh I think... he bought car summer 2010
Posted earlier, you probably didn't see it:
Update: Buddy just pulled the trigger on a used trans ($50). Looks good, bearings sound OK.
Just out of curiosity I am going to build this trans for a spare when I rebuild my si B000 with LSD. Until then its christmas time and I'm gonna get drunk!:bubbrubb:
No, its just part of it. No one part is separate from "business". Both the clutch teeth and the knife edge are there for a purpose and either one can make the brass ring ineffective in doing its part of the job for synchronization.
The inside edge doesnt have to be razor sharp would eliminate all but new brass as being bad, it just needs to be "knife like". The only job of that edge is to cut oil away and semi-grind into the conical surface of the gear its speeding up.
1 - 11 of 11 Posts
