1 - 2 of 2 Posts
9
Im nearing the end of this project and Im running into some road blocks
when I received my engine it came with one fuel injector connector broken I know I will have to replace at least that injector. My question is how do i set up the wiring to the injectors the engine was dpfi before the swap I am getting a p28 ecu 4 wire o2 sensor obd0 to obd1 ecu conversion kit. but I dont understand how to hook up the fuel injector wiring. The engine came with a cut off harness off of the fuel injectors.
Any help would be appreciated.
thanks in advance
C
Well did you allready convert it to mpfi? If not than i would say sending it out to Rywire.com and having them do the whole conversion, converting it to mpfi and obd1. That would fix the injector problem and make the swap better overall.
1 - 2 of 2 Posts
