1 - 18 of 18 Posts
I tried to replace my axle seal tonight and I ordered part # 91205-PL3-B01, the I.D. is larger then what I took out. Does anyone have the correct part #? It's a 1991 Civic Si with the standard D16 in it.
90-91 Si Honda parts database is messed up, order a seal for 92-95 drivers side.
Should be 91205-PL3-A01
B01 is for Wagon RTAWD and B series, 90-93.
sweet, the measurements seem to match up perfectly.
Is 91206-PL3-A01 the correct seal for the passenger side?
Heres what I do anytime i take out a cv,,,,Go to your local bearing supply house, bring the seal in with you and they sell you a new one for 3-4$ make sure to get a seal with both the axial, and radial wiper. (as a conventional seal usually has just a radial wiper)
usually the bearing supply house seal will be a little thinner...eg 6mm wide,,, vrs your stock seal at 8mm wide. This is not a problem, just be sure the face of the seal is flush with the cast boss on your transmission- when installing (I hand start make sure its square, then drive flush with a 2x2x1" thick block of wood), clean and apply oil to seal faces.......and your done.
D-Series Destruction Master
Heres what I do anytime i take out a cv,,,,Go to your local dealership and get the correct part the first time, all the time.
But how can you get the correct part if the parts database is wrong????
91 civic Base
part number 91205-PL3-B01 for left and 91206-PL3-A01 for right side.
found these parts numbers on World Pac, the company i work for orders parts through them for OEM replacements so they should be good numbers.
bones right, 5th gen dx axle seals.
had this very same issue on my second tranny swap on my 90 dx 4dr
pain in the nutsack
91205-PL3-B01 is wrong number, they are just copying Honda's fuckup.
bone, you should throw that info into one of your many tranny threads for sticky powah.
the honda dealership parts guy was flabbergasted that *GASP* hondas part numbers were wrong!!!
lol
lol
I'll bet it is already in a sticky somewhere.....what we need, moar stickys :(
1 - 18 of 18 Posts
