1 - 20 of 27 Posts
1999 Civic hatch
Sup all
Here's what happened, I installed a 6G EX transmission with a Stage 3 XTD clutch disc and a resurfaced flywheel. I reused my old pressure plate. I wanted to use the XTD pressure plate but it wouldn't fit on the flywheel for some reason. None of the holes would line up.
Anyways, we bled the line then turned it on, but it made a disgusting clunking sound very similar to a spun rod bearing. As soon as I let go of the clutch it would go away and it would only make a slight winding noise as if a belt was loose.
Also, it would go into gear and out of gear with no problem at all. But it wont spin the wheels. It did spin em for a cool minute and the MPH was working, but then it stopped.
Anyone wanna guess what it is?
wrong clutch disk..and now its broken
Certified O.G.
A Shitbox
Something (flywheel/PP) didn't get torqued down properly? Throwout bearing shit out? Wrong combination of disc/flywheel/PP?
94 civic dx
I agree axles are not seated
axles arent in, and it ate the end of the axle off when u let off the clutch.
did you take the tranny down after you heard the noise???????
94 civic, 90 talon
I say axles, if not, you will find the problem on dissasembly. If you did it once you can do it again.
94 civic dx
He said the car won't move, hence the axles.
Unless he took the tranny apart for some reason and didn't reassemble it correctly.
94 civic dx
It's funny how important 10 bux is nowadays lol.
Clearly you failed to properly lubricate your phase inducer which caused it to go out of sync with our universe. To properly resolve this issue please refer to the owners manual of your phase inducer Article 83 subsection 3F.232a.
You're welcome.
formerly Kit88
ek hatch
flywheel loose??
1 - 20 of 27 Posts
