1 - 20 of 32 Posts
yellow bar for me
viper blue 92 eg
ok i think i can get a decent deal on some SRP pistons for a d16a6. they are rated at 8.5:1 compression. after doing some calculations on the compression calculator, i found that these would yeild a 9.6:1 compression in my z6 build. would this compression be ok for say 300whp on pump gas and 400 on a race tune. of course it will be fully tuned by trackmasters in Huntsville Alabama with crome pro. or should i find a thicker head gasket solution. or not even use these pistons at all?
discuss, now!
Reactions: TunerToys
I personally think you would be fine on 9.6:1 pistons, provided that your shop knows how to properly tune a higher compression engine on boost. Doing the setup this way (with higher CR) will increase your power at the low end, when you are not in boost, making the car faster overall.
If you are concerned about the abilities of your shop to tune a higher CR forced induction engine, you might spend some of that saved piston money on a J&S Safegaurd.
Craig
yellow bar for me
viper blue 92 eg
links and info on the safeguard. i have heard of it, but i dont know much about it. i also plan to run methonal injection.
"ill race you after i refill my washer fluid, lol!"
I think some people have ran up to 10:1 static compression before. The only problem I see is keeping at least a 91 octane level and a very good tune to really prevent detonation. And shit, if all else fails buy them SRP's and sell them to me. :wink:
yellow bar for me
viper blue 92 eg
Discussion Starter · #8 ·
thanks guys. im getting the pistons today. and i think i am getting my z6 swap today also. anyone want a freshly honed and painted d15b? lol
Random Hero
Range Rover
I don't think 9.6 is all that high. Reasons people run 8.5 is: safer/easier to tune and if you want to run a large amount of boost.
You'll just have to compensate in the timing map, no reason to worry about preventing detonation, after it's been tuned.
with a forged setup, and that compression, you should be able to make a really aggressive tune, especially with water/meth injection.
yellow bar for me
viper blue 92 eg
Discussion Starter · #13 ·
cool. thanks guys. where is some good info on the J&S safeguard? or is it even necessary.
I'm doing the same as you, except i'm using a y7 (same combustion chamber)
I bought the 8.5:1 -6.8cc srps ironically from craig at tuner toys a couple weeks ago :p
yellow bar for me
viper blue 92 eg
Discussion Starter · #17 ·
ya arthur is pretty good from what i heard. where are you located?
yellow bar for me
viper blue 92 eg
Discussion Starter · #18 ·
1 - 20 of 32 Posts
