see above
how close or how far is the timing off with the use of the first gen integra belt. does anyone know the tooth count for either belt.
im having this discussion with my friend who is sure that the dohc zc using the first gen integra belt is close .. and that my issues are not timing related... just something im mulling over in my head.
i do know the correct belt for the jdm dohc zc is the 88 prelude si belt.. im just wondering how much of a difference using the d16a1 belt makes..
I AM NOT TRYING TO USE THE FIRST GEN BELT> it is already on the car, and in my hand is the correct belt. the motor came this way... i didnt think to check what belt it came with. but now i know the errors of my way. it will be fixed correctly.. as soon as i get this damn pulley bolt loose.. (i am also not driving the car. )
88 Prelude 2.0 Si timing belt (same as on the 88 and up DOHC ZC)
length = 118.11cm - width = 24mm - no. of teeth = 124
86-89 Integra D16A1 timing belt
length = 122.89cm - width = 24mm - no. of teeth =129
DOHC ZC camshaft gears have 34 teeth and the timing belt gear on the crankshaft has 17 teeth
86-89 Integra D16A1 camshaft gears have 40 teeth and the timing belt gear on the crankshaft has 20 teeth
you cannot mix and match any of these items
see above
upon further inspection, the part number for the belt checks out as a napa 88 prelude si belt. 250142 i think is the number. so the belt is correct.. now i was told that the timing is close, but 1/2 tooth on the crank side due to the belt. now the belt is super tight.. and i havent visually checked timing my self.. as i have no timing covers ( i have them but i can not get the pulley bolt off) so that means ignition isnt set.. nor is the timing verifiable.
short story. dohc zc swap. obd-0 basemap by acidbeave.
pm6 socketed and chipped.
problems.. runs like a dog under 5k rpm. no balls in the lower rpm range. .. also has a strange idle issue off throttle sometimes.. and almost seems like a tps issue.. lots of bogging when getting back in the throttle at low rpm. a sort of shudder.
now there is no codes.. and wasnt ever any codes after the swap. it just does not perform like i think it should. motor idles fine at start up, and runs ok through the rpm range.. .. any insight or help.. would be appreciated..
my first step is to check timing to see how bad it is.. i will report back with more info when i can. thanks guys.
see above
*added info*
when i got the chipped ecu, the chip was floating around.. bouncing about in the ecu case, i have had some problems with the zif. socket and have since removed the zif and inserted the chip directly in the board. that has cleared up some of the problems with the strange revlimits in the gears.. now all but first gear revs out... at 5.5k in first there is a spark cut.. or rev limit.. that shouldnt be there..
is there reason to believe something has gonna awry with the ecu. with no cel. or other problems.. (this basemap runs on another members car just fine).
see above
update again.. switched ecu for a pr4. runs about the same.. lil better.. but still dog ass in the bottom then really comes alive around 5k.. my bets on the timing being off more than the quoted 1/2 tooth..
stay tuned fellas.. imma get it. =)
see above
update.. fixed the timing, *or so i think* still kinda gutless in the low rpm. dual cam zc motors are new to me,, i know they carry their tq higher in the powerband. .. seems i have a dead spot in the tps. but ill know more tmw.. it runs ok.. but i think it should feel faster than my 4dr b7 eg...
as noted above, you can not mix and match the zc/d16a1 stuff, but you CAN use the 89 integra cam gears, crank gear, and belt as an alternative
i know this works, because i did the opposite.. on my d16a1, i have the prelude belt, zc cam gears, and the zc crank gear
