1 - 6 of 6 Posts
88 ED6
Does anyone know if the 88 DX differential will work in a DOHC ZC transmission? Reason being is so I can run the unequal length axles; my motor doesn't have the holes for the intermediate shaft.
Crx
i cant help you with your question but,
im running a driver side crx axle with the hub from a gsr axle, i just cut the boot off put the hub on the axle with new grease the 3 ball bearings line up perfect and then just used a quick boot kit
never gives me any problems.
88 ED6
So you just put GSR ends on the CRX axle? Sounds like it would work, but I don't have GSR axles anyways lol.
won't fit, DX has 35mm bearings, Si/DOHC has 40mm.
You need a 40mm Si diff? I have a few extras.
PM or email.......
damn, bone beat me to it. I have tons of those diffs collecting dust
1 - 6 of 6 Posts
