1 - 4 of 4 Posts
Ok guy I'm kinda new at this but I have a crx 88 hf with a brand new d16a6 in it and its boosted with a garrett t3 t4 kit running about 8 lbs ok so I have come across some dsm 450 blue top in jectors off a turboed eclipse now my question is one will they work plug and play and also what about my stock injector box do I need another one and if so off what kinda car the car is still obdo if that helps
Ok but they will just plug right up right.. I got a chipped pm6 from xenocron with a base map set up for my motor turbo what boost. I'm running and for dsm 450s so u think ill be ok?
besides needing a tune, they will plug right in and work perfectly on your set up. your factory resistor box will run them fine, POSSIBLY just some SLIGHT modification to get the clips to snap on, but you shouldnt have to really.
1 - 4 of 4 Posts
