1 - 17 of 17 Posts
I was wondering if any body knows the gear ratios on the 88-91 AWD 6spd civic tranny? or if there are any differances between the years. thanks.
-Jason
why wont it swap in? it bolts to an A6 right? or is the chassis diffrent from the AWD civic wagon to the civic hatchback of the same years?
The H Badge is it!
91 crx
honda made a 6 speed for the civic?
and the real time 4wd system is very weak.. cant handle more than 180hp or so... at least thats what ive heard
D
Is he REALLY going to break 180 HP?
K2e2vin said:
Is the old school 4wd even real time? I thought it was just a simple all-time awd.
the CRV uses a dual pump system and the civic AWD used a viscous coupling. I wanted to just throw the 6SPD in and not connect the rear driveshaft B/C I have a 4SPD right now and it is teh ghey and I can pick up a 6spd in good condition for around $50
the shifter setup is cable vs your rod setup.
Just get a 89-91 DX tranny and be done, listen to me for once!
'91 CRX Si
you need a 5spd dx tranny??? im in cola sc..... have one in the garage...
1 - 17 of 17 Posts
