Performance has nothing to do with how high the octane is, octane has to do with the likelyhood of detonation.I'd go with the highest octane available boosted motors performance are directly related to the quality of fuel used
How does one "cheap out on the tune"?? The person tuning my car knows what they are doing, how much they get paid has nothing to do with it.If you are cheaping out on the gas, i wonder how badly you will cheap out on the tune, which directly relates to how well your car will run with the fuel you use.....................
Y dont you try it and let us know what happens :TU: since u can learn by trial and error...Performance has nothing to do with how high the octane is, octane has to do with the likelyhood of detonation.
I know it isn't the "safest" route to go, hell if I was really worried I'd be putting in 104 octane everyday. I am more interested in "learning" what the engine can take and cannot take.. If nobody has ever tried it then say so, until someone does nobody will ever know. I have read about people that run 15+psi on 93 octane. So would it not stand to reason that you may not need such high octane while running less than half that amount of boost??
:TU:Use HIGHER octane!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Some newer vehicles actually have a octane sensor in the fuel tank, if you don't have higher octane fuel in the tank it changes the timing.uhh yeah it does I had an SE supercharged nissan xterra and when I didn't use the highest octane the performance sucked
The same ammount of heat is contained in a gallon of 87 as there is in a gallon of 93. However, you can compress the 93 more without it detonating.Performance has nothing to do with how high the octane is, octane has to do with the likelyhood of detonation.
87 works fine, but id still run 92 to help avoid detonation
i accidentally filled up on 87 once after i was turbo, never had an issue. i knew i shouldnt beat on it until my next fill-up, but i did anyways. it ran fine, although i had a conservative tune
Yes, you are right.. in my earlier post I was more or less poking fun at people that seem to think higher octane fuel has "more power" and will make your engine "run nicer" Hell you even see the gasoline companies advertising that, and it's a bunch of BS! I used to get people trying to talk me into putting premium fuel in my motorcycle cuz it "makes it run better" I'm like wft for? it has a compression ratio of 8.5:1 At this point these same people would look at me with a blank face cuz they had no idea of what I was talking about, and I would just laugh.The same ammount of heat is contained in a gallon of 87 as there is in a gallon of 93. However, you can compress the 93 more without it detonating.
PV=nRT
Higher octane allows you to run more boost thus making more power.
