1 - 6 of 6 Posts
Hey everyone I’ve currently changed the injectors and the dizzy cap and it’s stopped the sputters slightly but now it takes a little to get her started and now it sort of has a dip in power...
It doesn’t sputter but struggles to get to 4K revs then the high pressure fuel kicks in and drives fine, was wondering if anyone has had the same problem or knows of what it could be ?!
Discussion Starter · #2 ·
Sorry forgot to add the injectors I put in where from a spare engine I had so not sure if they were bad but I took the chance they weren’t
Did u test your fuel pressure and FPR?
How’s your fuel filter?
How are your spark plugs?
How did they look?
Spark plugs wires test within specs.
Test the coil make sure it’s in specs
Any one of these things would hurt the performance of your engine. Hope this gives you some ideas. Good luck.
Discussion Starter · #4 ·
How did they look?
brand new spark plugs and leads,new fuel pump and filter plus new fuel tanks and lines, haven’t checked the fuel pressure yet
1 - 6 of 6 Posts
