1 - 1 of 1 Posts
My car...or my truck
Hi All,
Didn't see this here and had to look it up elsewhere, figured I would share:
12v Constant (Battery)= White with either Blue or Yellow Stripe
12v Switched (Ignition) = Yellow with Red Stripe
Ground = Black
Left Front + = Blue with Green Stripe
Left Front - = Gray with Black Stripe
Right Front + = Red with Green Stripe
Right Front - = Brown with Black Stripe
Left Rear + = Blue with Yellow Stripe
Left Rear - = Gray with White Stripe
Right Rear + = Red with Yellow Stripe
Right Rear - = Brown with White Stripe
Found this here www.installdr.com/harnesses/ha-wiring.pdf
If something is known to be incorrect or misleading, post up and I will edit this post. The pdf says to use the same wire from one of the speakers for the "power antenna", I don't suspect many of us have factory power antennae on our cars though lol, I just ignored it.
Thanks,
Rob
1 - 1 of 1 Posts
