1 - 12 of 12 Posts
wheres my money man!!
seen tis on another forum thought it was Neat-O
Bike cost about 60k lol
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/KzVngeuThFM&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/KzVngeuThFM&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
ministry of mayhem!
93 honda integra
whoa. supah dupah penis pump yo.
lol.
91 CRX Si
you are just as bored as I am.......
tell me about what is need to run between open loop and closed loop on ecTune....like you did on your SOHC Type-R.......
duh
how the fuck would you hone that cylinder?
Pretty much just a wideband. If you use eCtune it will take the wideband's 0-5v output and you can pick what AFR you want it to tune for in closed loop.
If you don't have eCtune, and want to do lean burn, grab a cheap LC-1 and reprogram the 0-1v narrowband output so that whatever AFR you want the ECU to tune for is 0.45v. You can connect to the LC-1 with your USB-serial cable that you picked up for that fancy battery charger of yours. Pretty cool stuff.
I wish I'd played around more with FE on that setup. I don't think I would have gotten rrussell's results, but I could have broken 55 mpg if I'd kept my foot out of it and played with a leaner mix + ignition timing.
1 - 12 of 12 Posts
