1 - 10 of 10 Posts
I got Bit by the Boost Bug
Anyone know where I could pick up a set of Pm3 pistons in 75.5mm bore for my d15b2 besides fjt,Im awaiting to hear from him,but i dont think he has any.Anywhere you know is helpful thanks guys:)
Well?
majestic, or any other honda dealership for that matter
I figured majestic,But there about 170 for just pistons minus rings,I know fjt has the whole set for less than that,Butnot sure if he has 75.5 in stock.
formerly allnaturalrex
try ebay
Hi, FJT has only 75 and 76mm YCP PM3 pistons. That's the answer I received a couple of weeks ago when I was looking for the same. Did you look at P29's? Why not those?
Because i would like to run the run the flat top pistons,Flat top is better from what i have read up on.And i was going for 75.5 to have that little extra to go if i need to later on.
I got 76mm ones from FJT, why you don't want them? But AFAIK FJT has 75.5mm PM3s too. Atleast he've had.
Cause 76mm would be fine,Just if i had 75.5 i could still rebuild that motor later down the road if i need to bore more.76 would work great to.
1 - 10 of 10 Posts
