1 - 20 of 28 Posts
Ok i been looking and i am on my way to getting a bigger turbo so i can lay down mid 400whp i have a garet 50trim 82a/r now i been looking at 57trims with a 63a/r my ? is will this 57trim get me to mid 400whp on my built d16z6.
yes it will also have a much more fun spool to it
althought iirc you can reach that witht the snail you have but would be laggy
wait what. 50 trim flows more than a 57? talkin about the exhuast ar?
so u guy's think the 50trim will get me mid 400whp with these other supporting mods in my motor?
bottomend:JE pistons, Eagle Rods, and all oem honda bearings
head:arp head studs, hot tanked and got an 5 angle valve job
also supertech valve springs and retainers only thing i am waiting to come in is my camshaft?
My tunner say;s i want make past 350whp with that turbo so i didnt no if i needed to go ahead and get the bigger turbo or not>
so i guess i am gathering the 50trim is not going to get me 400 and the 57trim will barely make it :( should i go 60 trim to make that mid 400whp range also i should be able to rev pretty high so will that lag really matter that much if i am doing street pulls?
insert user title here
the idea is the get the quickest spooling turbo that meets your power goals efficiently.
its like buying a sc61 to go only 200 hp while another guy has a t3 with the same goals. who do you think is going to be the faster car?
1 - 20 of 28 Posts
