1 - 7 of 7 Posts
What is the max whp people have safely tuned to with 450cc injectors? I have heard 300whp is the max but id this the case?
Random Hero
sleezy rule of thumb: (2/3)*injectorcc = max hp @ a 'safe' duty cycle (~80%)
In the DSM community it's recommended to get something larger for anything over 300ish HP. But I'm sure you can find someone that made more power on 450s. Check the DSM boards/forums.
Here are the guidelines we use for sizing injectors.
Flow Rate vs. HP Level
(Flow Rate for each injector,
in a four cylinder setup.)
310cc 200~220whp
370cc 220~280whp
440cc 280~330whp
550cc 330whp~380whp
660cc 380whp~425whp
720cc 425whp~475whp
880cc 475whp~525whp
980cc 525whp~600whp
Hope that helps,
Craig
Fuel Injectors from Tuner Toys
Anyone know if Y8 injectors can be used with a P28 (Z6) ECU? Do they even plug in to the P28 injector wiring harness? I know Z6 injectors are 235cc and the Y8 ones are 240cc. A friend of mine have a D16Z6 and asked me if this can be done... just wanted to know for sure...
bigfoot said:
i have them, they work great, i think they can hold more then 300hp dsm 450s FTW!!!
yeah I think they actually can hold more than 300, Ive heard different stories tho...
1 - 7 of 7 Posts
